TwinTurbo.NET: Nissan 300ZX forum - another solution. after using penetrating oil, always
mossyoak
on May 25, 2008 at 9:32 AM
Thanks, I think im going to try some pb blaster. Let
posted by evan3(ca)
on May 24, 2008 at 09:24 PM
tap tap tap which allows the oil to penetrate further in, then take a chisel placiing it on the the circumference of the drain plug, and and gently tap forcing the plug to turn in the proper direction.
Need help removing a stripped transmission drain plug.
evan3(ca)
11:54:57 05/23/08
maybe a easyout bolt extractor (n/m)
john90zxtt(OH)
13:51:35 05/23/08
Maybe take a bolt with a square head that will fit in there
SlicktopTT
15:07:32 05/23/08
Thanks, I got a new one. Everything I try just seems to
evan3(ca)
16:39:52 05/23/08
Here's what someone else ended up doing -- see link...
jzack
09:11:08 05/24/08
Sure you can't get an impact wrench on it?
lakerdude42
20:48:23 05/23/08
Also if you don't think you can hold it up tight enough
lakerdude42
20:55:29 05/23/08
An impact wrench would only make it worse
spyhunterTT
18:13:00 05/24/08
Weld a bolt/nut to it. works like a champ. (n/m)
Crim
09:30:09 05/24/08
evan3(ca)
21:24:12 05/24/08
another solution. after using penetrating oil, always -
mossyoak
09:32:55 05/25/08
